Snorkles. Is there a Difference?
The Airflow, which I have, doesnt work with ABS because it goes straight through the inner fender, where the ABS computer would be.
The ARB routes the hose behind the outer fender, between the inner and outer fender, and comes up where the inner fender turns flat, right in front of the air intake. It should not interfere.
Airflow through fender
ARB, if you look right below the bushwacker, you will see the black hose that is going up to the airbox. Easily ripped out if you flex a lot.
