alexgalexg
- Connecticut
Welp... Todays new problem with my wonderful AMC product is its smoking. Its not consistent either. Doesnt have to be when the engine is cold, and doesnt have to stop when the engine is at proper running temp nor does it happen every time I drive it. But nearly every time. Just a cloud of white smoke out of the tail pipe. This is not water vapor or just because its cold. This is literally a plume of white smoke. A lot of it. My oil filter arm does leak but this is not a case of oil hitting the exhaust and causing smoke. This is coming strait out of the tail pipe. I cant say that I have noticed any difference in power and it doesnt buck or stall. Any ideas? 95k on engine 180k on body.
1998 Xj 4.0 Inline 6
New:
Intake gasket, fuel pump. upstream 02, plugs, leads, dist, rotor, starter, thermostat, harmonic balancer, belt, radiator, brakes and disks, master cyl and full flush. Engine oil is changed every 4k with castrol edge and mobil filter
New:
