check for small leaks in and around the injectors, and at the quick disconnects for the fuel lines. Also check the fuel pressure regulator at the end of the fuel rail. If rust is a possibility, check the fuel lines all the way from the rail back to the tank.
You don't say what year, but if it's an older Renix 4.0, it's pretty common for the injectors to develop leaks at the electrical connectors.
Gas evaporates so quickly that it may take some sleuthing to find a very small leak, and you'll probably have to do it with engine running. Look for little damp spots. You may never see a drip.
If you do find a leak, fix it fast. You really don't want your Jeep to burn to a crisp, and it really can if it has a fuel leak.
Finally, make sure you're really smelling it from the front. These things can be deceptive sometimes, so while you're at it check the under-chassis lines, the filter and the tank. Steel tanks can rust around the seams or at the top, and produce a steady gas odor without ever dripping.
e.t.a I see John b beat me to it. O-rings are a cheap fix, and worth doing, but do note that if it's a leak in the injector itself, it cannot be fixed, so check the connector area carefully.
