4WDlifeform
- Beaver Falls, PA
Hey guys. First off, I am a mechanical person. Electricity scares me, but sometimes I screw with it for fun...
For those of you that know some electrical stuff, here is my situation - I was given a pinball machine from the 1970's. It works great, but the flippers are mechanically connected to function off of one solenoid. I want to actually remove the mechanical component, and add in another electrical component... what is wrong with me... :looney: I want the flippers to operate separately.
Here is what I can gather from the original solenoid:
Circuit voltage is 33 VDC
Coil Resistance is 4.3 Ohm
Travel is about 1 inch
This is the closest I could find one on McMaster Carr:
70155K5
http://www.mcmaster.com/#linear-solenoids/=emw7ba
It is rated for 24V. Keep in mind, this is for a flipper, so its duty cycle is only a second at max... Not sure if this is suitable for a 33v application?
The existing solenoid is pretty beef... I would have to guess about 5lb of force, but its really hard to tell.
Another thought, Should I just get two new ones? Or, I could replace one of the single solenoids elsewhere on the table with the new one, then I will have two similar solenoids on the flippers. This would prevent one seeming different than the other. The same solenoid is used all over the thing.
Open to thoughts. Thanks in advance!
70155K5
