builder
- Yucca Valley california
Exception's xj's with 242 full time feature should be set at zero.
i got 4.5" in the front and currently im about a 1/2" toe'd in... i havent adjusted mine yet but no DW for me, just alot of bump steer to me... like going over speed bumps the steering wheel likes to jump(turn) side to side a inch sometimes
when i had a shimmy in my steering at 2" lift i was out on my caster, after doing my 4.5" coils and tomken LCA's my shimmy disappeared, im assuming the alignment shop doesnt know how to align a lifted vehicle and set your alignment back to stock spec's... if it was me, i'd adjust your lca's out 2 turns, install take for a drive, if it doesnt work, do it again until it either gets worse or gets better, thats what was suggested by this 4wd shop on how they do it and told me thats what i should do to fix my shimmy.
just an idea, can take it with a grain of salt if you feel im wrong.
checked the wheels for movement, but I could move the whole steering and nothing seemed loose. That is, when I grabbed the wheel at 9 and 3, the whole steering would move, and nothing moved on the 6 and 12 axis. I'm thinking of taking it to shop...any suggestions?
i thought i'd post up again here, as i've been having a similar issue. i finally got around to changing my visibly bad uca bushings-what a pita. at the same time, i swapped my stock lower arms for some aftermarket(skyjacker or rancho-not sure) fixed lower arms with poly bushings, mainly because i had them sitting around, then reset the alignment to 1/8" toe in. man, what a difference! absolutely rock solid at any speed, over the choppiest crap roads i could find. the whole ride is smoother, tighter, and far more "stable" feeling. no more dw period. :woohoo:
it was a cracked track bar bolt that didn't show itself until it was uninstalled and snapped on reinstallation.
