i'm trying to decide if this junk will suit me,
i'm building an MJ-crawler
planning to run coils and radius arms front & rear on what ever axles i decide to use, so 1st off i like the 75-79 ford f150 stuff but i would like to run lockers and 37-38 tires, so i'm thinking the d44hp from said probly will pop shafts if locked so maybe a dtroit true-trac or spicer trac-lock would be better in front, but i think the 9in will hold up even if i run a spool or full locker, i'm plannin on a stock or mild drive train such as 4.0 w/ ax15/np231j or similar
i found a set or running gear currently mounted under a F/S 80 bronco (has an older model front end swapped in)
they're supposed to be geared 4.10 w/ a limited slip unit (?) in the rear 9in.
the seller just recently bought the truck and plans to swap in 1ton running gear to mate to the beast which has a 460/c-6/205 from a 1ton truck, so he is willing to part w/ the axles (which do have sum upgraded Warn hubs and new brake calipers) for $500
also he will include some big lift coils from the front and sum spare axle shafts for the 9in and also sum old 15x10 wagon wheels
i know i'll eventually pop a shaft in the d44 & have to upgrade the shafts to hold up to the abuse this rig will see at places like tellico, gray rock and others..
do yall think this stuff will be a good starting point?
and is it a good deal??
