stoneattic
- Honey Brook, PA
Here's my setup, or soon to be when I get everything on:
I'm at 3.5".
I picked up the JKS BPEs for the lower front and upper rear shock mounts. http://www.jksmfg.com/bar_pin_eliminators.htm
I also picked up the JKS upper front shock conversion that eliminates the stud mount. http://www.jksmfg.com/bar_pin_eliminators.htm
I've also raised the lower rear shock mounts to be even with the bottom of the axle tube.
So which length shocks do I go with?
Any one else running a similar set up?
Comments, suggestions, flames, etc?
TIA!
I'm at 3.5".
TIA!
