Friday I lent out my XJ and it was used to tow a truck about 120 miles...Anyways I get it back today and everything's normal except for the fact that right at about 45 MPH there's a noticeable shimmy/vibration coming from somewhere BUT it's not there when you let off the gas, it's only there when your on the throttle in gear.
Almost feels like bad gas making the motor run poorly but that's not the case because it's only from speeds 45 and above in gear and on the throttle.
What could it be, transfer-case going, bad u-joint, rear end going?
90XJ, 4.0, AX-15, NP231, 193K
