law.74
- Too far from Moab
I purchased a scan gauge 2 about two months ago for my 00' sport but never got around to setting it up properly due to a busy schedule and the fact the unit went to sleep with the ignition on. I assumed that it was a setting that needed to be changed. I finally got around to messing with it again, but no dice.
I emailed the company about it and got this reply:
"The problem is in the vehicle. Some DCX vehicles will simply shut down the diagnostic link and refuse to respond to a re-initialization. This is in violation of the OBDII standard and they did correct the problem in later versions of the ECU programming.
It appears to be due to a combination of the ECU programming and the options in the vehicle. The problem only exists in a small percentage of DCX vehicles and sometimes goes away when the vehicle is reprogrammed.
At this time, no-one has found a way to get around the vehicle shutting down the link."
Anyone else encounter this issue?
Anyone reprogram the vehicle successfully, ie get the scan gauge to work?
I'd hate to pay a dealership to jack up the programming and still have the scan gauge not work.
