comanche91
- Sweet Home Alabama
I googled crown jeep disc brake kit; still could not find what pads/calipers/rotors Crown uses in their kit. :huh: I'd have to know that....
Summit appears to have the same kit for $333 and it is from Teraflex.
It is missing the soft lines so add another $40 or so.
That still $75 less than Rusty's and Summit's reputation is better.
http://store.summitracing.com/partd...54400&view=1&N=700+150+4294922533+4294839009+
None of the kits include parking brake cables.
That price is for part number 004354400
A few weeks ago I explored this. I called terra flex. For my '99 XJ I need part number 4354420 Summit has it, but it's not $333 it's $628.95
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TMI-004354420&N=700+115&autoview=sku
Thanks Guys:cheers:
How much do you think I would spend on pick and pull parts?
I've not done much pick n pull here on Long Island, but if it's like other stuff, it will be quite a bit more than what I'd pay in Florida or by you. I mean if I could source every thing I needed in one day for 200 bucks, I'd do it. I just dont think that's the case around here...
How much would it be if I sourced new parts?
As to Rusty's I've on two occasions, spent some time talking with him on the phone with him, seems decent enough. I know some folks who have had good luck with him too. If I ordered from him, I'd let him know I've herd some "bad things" and let him know that at the drop of a hat I would call Visa and start a charge back. Sort of very politely, of course, put him on notice. That has worked well for me in the past with guys I was worried about.
The words in the above quote will need to be eaten, in the not so distant future.......
Rusty is only reselling the brake kit, so it's probably OK.
Google: crown jeep disc brake kit
Summit does show two different kits, one with hoses, one without.
Must be a 'special' type of hose for an extra $296<g>.
Try ordering the $333 kit on-line and see what happens. What do you have to lose?
http://tinyurl.com/dbd5xz
It didn't take you long to jump on the band wagon...2 replies and your sold?
From the link you posted.
"Designed for big Ford housing ends."
According to one of the other threads, the cheaper kit is for 8.8/9" rears.
Anyone able to corroborate that?
(I don't know jack about any of the Vic, Ranger, or Exploder rears, nor what might be required to make parts from one work on an XJ)
i did 2 d44's via this http://www.jeepin.com/features/cvdiscs/ . using junkyard parts...
BOTH came out really nice,
the "15-20 year old parts" are stuff like backing plates and core calipers, nobody is telling you to run JY rotors/pads/calipers... so cut the BS that junkyard stuff isnt good enough for YOUR jeep
my advice? stay away from the kits.... peice it together yourself, with the stuff you want.
btw. dig your signature quote!
the backing plates are actually from a Ford Crown Vic, which already has the bigger hole in the backing plate and does not need to be opened up to fit a D35 or 8.25 axle.
I looked around the Crown site and it was not readily apparent that there was a rear disc kit for the XJ...
I might be dumb...
comanche91 said:I googled crown jeep disc brake kit; still could not find what pads/calipers/rotors Crown uses in their kit. I'd have to know that....
Brand names on pads & rotors aren't listed as the parts are sourced directly from the manufacturers. It is all new ZJ parts, stock replacement, down to the calipers & backing plates with all the hardware. That is where the price comes from as it isn't rebuilt stuff, all brand new. To some people, that's important, to others, not so much. I have personally seen the kits and they are good quality fwiw.
http://www.crownsupport.net/downloads/ they will be upgrading the old website soon to a much better format.
I don't think I spent $100 of my time in locating the parts, I probably didn't spend more than 2 total hours sourcing and picking up parts.
