Rick Anderson said:This vehicle is at stock suspension height, correct?
The new tires were balanced properly, correct?
Did you finish the swaybar bushings, I'd do the frame to bar bushings as well, its only a couple of extra bucks? BTW, your extremely likely to break the sway bar links trying to take them apart for the new bushings, most auto places sell new ones fairly cheap, but its just one more expense.
Adjusting the pre-load on the steering box should get rid of the play, that was what the previous poster was talking about when he said to put a couple of turns on the allen screw. Be careful on this, only do about a half turn at a time, you over tighten that pre-load adjustment and you'll chew up that steering box in no time.
Have you checked for play in the ball joints? Support the front axle with the wheels off the ground, use a 2X4 as a lever, see if you can find some play in the wheel/hub and the axle. Up/Down, In/Out and Tilt.
Front Wheel Bearings?
I hate to say it, but if everything above checks out, the only thing I can think of is the UCA/LCA Bushings. Even though they appear OK and you can't find anything loose, perhaps they may be soften and deteriorated enough that they don't stand up to the forces on the axle going down the road. Its a lot of work, and although you can probably get the arms and/or all bushings for roughly $80, thats a lot for just a guess.
Have you read any of the first page? Oh, and when I said "A BIT" on the screw thats what I meant, a half a turn would lock that thing tight.
