I've got a 2000 XJ that I'm installing the RE 3.5 kit on.
Rear leafs, are so far as bad as described, as far as removal. Passengers side wasn't horrid, but the drivers side front bolt decided to bust the weld nut off so the bolt just spins. No prob, I'll just go in through the floorboard to get it out.
However, I'm seeing that some folks are saying that the rear shackle needs to be removed also. I'm curious as to why? The directions to not mention that from what I've seen, and I don't understand why the new springs cannot just be installed to the factory shackles? Do I need to remove the shackle (upper bolts), for some reason? Was hoping that I did not need to after the front bolt fiasco.
Thanks
Thanks
