jeepsrock
- LA California
brand new napa map sensor.
pete
pete
Check your battery voltage at idle.jeepsrock said:brand new napa map sensor.
pete
Yes just somethng to check. Let it idle untill it starts doinking up then check the voltage at the battery.jeepsrock said:Are you saying that i should use a multimeter and check the battery voltage during idle ?
pete
That makes sence, some cylinders are running lean while others are ok, computer tries to make adjustments and can't.ren said:i know it sounds wierd, but I just got done changing my exhaust manifold for one that is not busted up, an dnow my idle is STABLE at about 700-750 rpm. I think that my manifold gasket was a little bit toasted and that caused my wierd idle. HTH
Ren (rapidly becoming used to working on the wierd and not supposed to be on there stuff).
A vacuum gauge is a great tool, you need to get a good one, it's is likely you have a leak around the intake manafold. The one I have is called a compound gauge, it has "0" in the center so the same gauge reads down to 30" vacuum and up to 60# of pressure. Just one question though, when you say the A/C quit, do you mean the vents went closed or the air just turned warm?jeepsrock said:Read the whole thread...i am talking about issues that can be effecting my rough idle. I mention the AC vent issue bc maybe thats a sign of a vac leak ? ?
pete
I would be careful with that, carb cleaner's so flammable and the hot exhaust is right there too.jlex said:Spray that carb cleaner around the intake manifold, too... not just the vacuum lines.
jlex.
