Pharaoh XJ
- Cairo, EGYPT
Hi guys, I ve tried everything this time & its really getting on my nerves, its my DD & I cant get nowhere.
Here is how it began; had to replace my freeze plugs so took off Intake/exhaust manifolds for the job.
After that it started idling really rough ( low) so replaced my intake gasket as I suspected a vacuum leak. Fixed it for 2 drives then went back.
Got some Carb cleaner sprayed on every possible location: Injector O-rings, manifold gasket, throttle body gasket & Butterfly pin.
Even got some scenting sticks ( smoke source) to check for any vacuum leaks.
Finally replaced my IAC fixed it for 2 more drives but was minimally idling, then went back to how it was.
Usually it fixes it self as soon as it reaches operating temperature & gets really bad & stalled couple of times under heavy load like: full steering lock & when in gear against the curb.
More info:
No codes
Defroster is acting up with AC on ( vacuum leak)
Exhaust manifold cracked
Please guys I am really pissed off & wasted a hell lot of time & money trying to figure it out.
Thanks
More info:
No codes
Thanks
