- Dracut, MA
I KNEW i recognized that. hahahaha. good stuff :cheers:
How exactly do better materials and tighter selection tolerances make a bearing smoother? And better lubrications will do nothing for your gas mileage.
Cherokee's don't get good gas mileage because they're American.
Duh
not wrong, per se IMO, but here's what i've got.Oh and correct me if I'm wrong on anything... I'd like to learn from any mistakes!
probably less than .5 gpm, if you had the worst stuff on the market and went to the best stuff for everythingBetter lubricants WILL do something for mileage, but it's very, very little... although better lubrication in everything driveline related will eventually add up to say, one mpg?
even more reason to own a manualI think I read that the aw4 is about 70% efficient... parasitic driveline loss SUCKS with them.
it could also have to do with the fact that the expansion ratio increases with longer stroke, so there's less extra power at the end of a stroke than stock. for normal size engines, there's still quite a bit of pressure in the cylinder when the exhaust valve opens, but having a longer stroke uses up some of that pressure.Oh, and methinks the best way to improve mileage on a 4.0 is to stroke it, balance it, open up the head, and get a new cam. Stock 4.0's may outlive cockroaches in a nuclear holocost, but they'll always come from factory with insanely huge tolerances and stupid balancing of the crank. Not to mention the HO cam has too much valve overlap, which puts the torque curve right in the WRONG spot for the XJ.
I think the main reason stroking it improves mileage is because of the tighter tolerances associated with an aftermarket rebuild, and that SMART owners break in the engine properly then switch to a high grade synthetic for more efficiency. Top that off with a change in the torque curve and even particularly heavy rigs can get good gas mileage...
haha... just don't design electrical connections. because whoever designs those designs them to break apart when you pull on them. it can make quite the headache.I decided today, when choosing between pounding on the new engine and sorting out my wiring harness, that I want to become a mechanical engineer rather than an electrical one...
By 20 or 30 MPG I mean mixed. I get a little over 20 on the highway but in town I get around 16.
And as far as the brilliant individuals tryin to get the thread closed, if you don't like the thread then don't read it, or post in it. It was a question worth asking but if you disagree, then simply leave. There's no need to instigate sh*t just for the sake of causing trouble.
you don't buy a cherokee for gas mileage
plain and simple
im happy when i get 16
I did. I get twice what my fullsize Jeep got. They're fuel efficient compared to other off road vehicles.
yes but not compared to most cars...
my jeep gets half what my motor swapped focus got and only 2/3 what my boosted saturn got...
Hence why I daily drive an 06 Accord that gets 30mpg
this gets back to trying to polish a piece of crap. it just can't be done.
I'm not complaining about the 46mpg my Jetta TDI gets, but diesels don't need to be emissions tested anyway! Originally, they have to run clean, but once you buy them you can do whatever you want to them including chips, nozzles, turbos, propane, nitrous, etc and noboy can do anything about it. Theres no "50 state smog legal" parts for diesels because none of the 50 states actually cares to emissions test diesels. Anyway, I do agree that we have much stricter emissions and safety laws here, but if you buy a diesel you can get around thoseJokes maybe? The XJ is actually french... well half french... just so you know!
... and the only reason we can't get good mileage is because we have ridiculous emissions requirements...
Europe gets to have all their happy turbodiesels with cheaper diesel prices... all because if a vehicle meets MPG requirements they don't have to pass the same emissions requirements... A bluetec(?) jetta supposedly gets 90 something MPG with respectible power ratings on a small four cylinder turbodiesel. I just read that it's being cleared for US emissions, but wont get the same power/MPG ratings... ugh!
Bluetec is Mercedes, TDI is VAG.
