aparke4
- Atlanta, Ga
no it is not a substitute for a quart - if u just changed oil it is ok to simply add to oil
I put Restore and some Marvel's in my 6 cyl (230,000 miles) about 1500 miles ago and there seems to be much more pep in the old dog recently. I am pretty sceptical about additives so I'm pleasantly surprised.
P.S: I also added the Marvels to the fuel.
When I do my oil changes, I usually put 5qts of oil and a quart of MMO. Then start her up, let her run for a few. Then check level and top off with oil. I do not usually use MMO in the tank, I usually do seafoam for that. On occasion I run some of that Chevron Inj. cleaner cuz I get it for cheap at costco.I was looking at marvel the other day - how much did you add to oil? to fuel? the bottle was twice the size of restore i think...
I also dropped in a bottle of STP oil additive to my other XJ - any pro or cons on that stuff? It is THICK! My 99 has some very mild compression issues and just wanted to try it out...
