katuah
- NotTheMountains :-( ,NC
Hello Colorado folks,
My mom & I are in Cortez and something in the drivers side front end right under my feet is popping like crazy.
It started after a bad stretch of potholes on I40 in Oklahoma. I tightened all my track bar bolts and such two days ago in Santa Fe, but that didn't fix it. After we went down & back out of Chaco it got worse. It does seem to be steering related as it pops when I turn the wheel, more the harder the turn. Sounds like fireworks trying to parallel park! The tie rod seems tight when I grab it and try to wiggle. I don't see any frame side cracking near the track bar bracket, and I have an aftermarket double-shear track bar and bracket so there's no tie rod end frame side. It doesn't seem to be rpm related at all so I ruled out front driveshaft u joint.
Is there anyone in the area who would help me out for a few hours with a jack & stands to check control arms and maybe replace the ball joints? I have tools but only a hi lift, which I don't like using for such things if possible. Barring that, recommendations for a garage?
