Djmack
- Travis AFB
Sorry if I offended anyone.
Anyway, I'm currently deployed right now. I dont know if any of you remember me saying at SierraFest last year that i have a 1990 White XJ. Well, it's sitting right now waiting for me to get back and do something with it.
The problem: Currently i have swapped CPS(Crank pos. Sensor) plugs, wires, Ign. Coil, and resealed the entire top end (Head gasket, valve cover gasket, exh/int gasket). After resealing it, i went to start it up, It took a second to play with the adjustment of the distributor, but it started and ran with out flaw. (Note: I did all the work to clean the grime and grease off. The last owner did not maintain it.) So, i got all excited, decided it was late and just cleaned up to finish putting everything together the next day. Next day rolls around, I was curious if what i did continued to work. So, i went in to start the jeep. It turned the engine with either no fuel or no spark. If i remember correctly, both were intermittent at any time.
So, im just sitting here in the desert trying to figure out cheap ways to fix it. Could it be the computer? Could the CPS be 1/100 of 1mm off? I have removed and refreshed all ground and Positive connections to the block, body, starter, etc.
The interior has been gutted and cleaned from top to bottom. It is a bone stock cherokee, and im just trying to get it running right and sell it. This would be an awesome daily driver with new shocks and brakes.
Help me yall.
Help me yall.
