my2monkeys
- Mission Viejo, CA
With my dvom back probing 3 wire connector, key off, extra ground hooked up . I read less than 1ohm, Koeo ,reads 1ohm. When I remove extra ground at this point(stock configuration) it reads 9ohms.
Is the 9ohms coming from the ECU? It must be, and is 9ohms anything to be concerned about? I don't know things when your talking electrical .
This is Cruisers tip I'm following, probably did it wrong:twak:
