cheapcherokee93
<----boat-manche
- Guadalahabra, CA
so my 88 mj, while now running okay is now having some idle issues. upon start up, sometimes it will jump to 2500 rpm and stay there for a couple seconds until it starts to go down to normal. i know this is bad because there is no oil pressure at start up so its wearing out my engine faster. it only does this on occasion but i still don't like it. second problem, after driving it and getting it warmed up, it mostly likes to idle a little bit high. high as in around 750 rpm in D and if i put it in Neutral 1000. i know it shouldn't be idling this high. sometimes it will bring itself down to normal level of about 750 in N and maybe 500-600 in D. i have read that cleaning the IAC is supposed to help so i cleaned it and at first it seemed like it was idling better but soon after it went back to its bad habits. i've read multiple threads on renix idle issues but they seem to say different things and explain different problems. so, any thoughts on what might be causing this? could my IAC just be bad altogether?
