- Roanoke VA
WOT numbers; ECU side 4.43, TCU side .17 or 4% (.17/4.72=.036 rounded up thats 4%)
That sound right?
That sound right?
xjtrailrider said:WOT numbers; ECU side 4.43, TCU side .17 or 4% (.17/4.72=.036 rounded up thats 4%)
That sound right?
Ecomike said:.17 or 4% sounds a little low at WOT on the TCU side, but I recall someone having theirs as low as 0.20 on the TCU side at WOT with no problem. As I recall mine is a lot higher at WOT on the TCU, but I have something like 4.98 volts input on mine, so mine would be higher.
So what did you change that seems to have fixed it?
xjtrailrider said:Its running pretty good since the TPS adjustment but I thought I would check the dist. indexing for kicks. With #1 TDC compression stroke I shot this pic of where the rotor is sitting compared to where #1 terminal is. The terminal location is marked by blue sharpie, as you can see the rotor is just past the #1 terminal location near the #5 terminal. I think that would make it retarded, I've run it one tooth back before and it just didn't run right.
So for kicks I put it back together and fired it up and with my Timming light with advance feature I checked the timming;
Closed loop idle-15 degrees advance
2000 rpm-36 degrees advance
I don't have a spec for the timming but does this sound correct?
I know that most engines run 8-10 degrees at idle-base. I have no way to check the base on a XJ 4.0, only the static timming and where ever the ECU puts it while running.
Any advice/opinions on the indexing of the dist. and the timming advance?
Ecomike said:That is definately one tooth advanced, too far. It should be pointing directly at the blue mark where the number one wire goes. Maybe you fixed some other things like the TPS since you tried that spot. The timing light is of little help with electronic ignition. There is no spec for the 4.0 timing because it is electronic, computer controlled, from what I have read.
Ecomike said:Very strange, that should have fixed it. Try disconnecting the entire battery positive cable and clamp and wires from the battery and with the ignition turned on short the detached positive cable to the ground side of the battery, that should quickly drain any capacitive memory in the Renix ECU. Then reconnect the battery and see if starts and runs, if not put the distributor back where you had it and we can all scratch our heads for a while.
If that does not work, I would suspect something is of by one tooth in your timing chain, gears, or cam.
Personally I would leave the tab alone, not sure what the real issues are with removing it, I know some have said they did it before. I have had Renix memory issues when I reset a TPS idle possition. They went away after about 3 shut downs and restarts, but that was idle TPS voltage memory issues. I will be real curious to see if clearing the memory solves your problem too.xjtrailrider said:I'll reset it! Do you think trimming off the tabs at the dist base and moving the housing will help fine tune the timming? I know the ECU does this but can I fool it into thinking all is well.
Ecomike said:Personally I would leave the tab alone, not sure what the real issues are with removing it, I know some have said they did it before. I have had Renix memory issues when I reset a TPS idle possition. They went away after about 3 shut downs and restarts, but that was idle TPS voltage memory issues. I will be real curious to see if clearing the memory solves your problem too.
Shorty said:as the rotor turns, it's gonna fire when it reaches the terminal which would actually be before the engine reaches TDC. As pictured, the ignition timing is advanced-- not retarded.
xjtrailrider said:OK, I guess I'm the retarded one! lol!
Ecomike said:I've always liked to think of myself as advanced!:yelclap:
Slo-Sho said:From the pic of your rotor the ECU isn't taking advantage of the full length of the rotor. If you are using the stock crank positioning sensor do this;
Set the crank pulley to 12 degrees before top dead center and adjust the distributor so that the number one terminal on the cap is directly in the middle of the rotor. This will get your fuel sync and ecu timing control more accurate.
