tbburg
- Scottsdale AZ
This last weekend I was talking to a dealership mechanic friend who had just completed a gear change on a 2014 JK. When he took it for a test-drive, it threw a code and set off the check-engine light. Several hours of research and testing showed that the problem was a discrepancy between the driveshaft (transmission output) speed and the axle speed - as measured by the ABS sensors. There is a way to specify gear ratio in the factory computer, but it is limited to factory option gears.
Apparently there are re-programmers available that will hack the factory settings.(Probably voiding the powertrain warranty.)
The discussion ended with us both wondering if this was JK-only, Jeep-only, or something industry wide. Any experience with re-gearing modifying the powertrain on a new vehicle?
