HillbillyLes
- Missouri
I need an adjustable track bar for my 94 XJ. It originally had a 4"/3" Trailmaster lift which instructs to use the stock track bar and drill a hole in the axle bracket to make it fit. That worked fine but when the stock rear leafs with the 3" add-a-leaf started to sag a bit, I went with a set of RE 4.5 springs in the rear and added 1.25 inches to the front via a poly spacer.
It now sits roughtly 5" over stock but I had to flex the passenger side up a bit to get the track bar to fit, even in the 4" lift mount hole so I know is only a matter of time until something wears out or breaks.
Since this is my first XJ, I am looking for recommendations or opinions on which of the various brands of adjustable track bars everyone uses or prefers.
I do 95% driving on the highway daily with any offroading ususlly pretty docile and slow...hunting or exploring type. Though I do want something that will hold up should I decide to push the envelope.
Thanks, in advance...
Les
Les
