That is exactly the same kit I have, but I upgraded a couple of components:
HD track bar + ~$20
HD track bar bracket + ~80
Adjustable lower control arms + ~$30
Don't remember if those prices are right, but the kit came with Rancho 5000 shocks!! Shipping and everything came to just over $900
Might need the SYE, depending on how it does after lifting, but I've seen them more around $300-$400
Track bar is included in the RE kit as well as stainless brake lines front and rear and the generation II sway bar disco's so you should be good if you can get away without the SYE..... Keep in mind that you probably will want it eventually even if you don't have to get it now, but it is recommended...
HD track bar + ~$20
