YosemiteJeeper
- California
Rebuilt engine won't stop...Please help!
1991 XJ Laredo auto 4.0L Six cylinder : I rebuilt the engine completely making sure to take my time and do it right. Now its in and it won't start. Here's what happens...
I turn the key and it turns over fine. Shows oil pressure. It sounds like its starting to fire up but only for a second then it goes back to just turning over. Before I replaced the CPS it didn't even try though. It does this a few times--sometimes more sometimes not at all--during a ~10 second attempt. I smell fuel from the exhaust, so my thoughts are its getting through at least some of the injectors. I pulled my brand new Bosch platinum +2 plugs and 3-4 of them were coated in what appeared to be gas (smelt like it) So I don't know if they're firing.
I checked the plug wires, checked all the connections I could find, hit 'em them with cleaner and dielectric grease. Checked my grounds they looked fine and I refreshed some of them. Cleaned inside the distributor cap. I was very careful in setting the timing. As I said everythings brand new so I shouldn't have low compression because of piston-cylinder clearance, head gasket, ect. Head was rebuilt. I don't have the equipment to test compression, fuel pressure or spark. And nobody's willing to hold the wire/plug while I turn the key to test (can't say I blame them...) I might be able to get it if other things don't work.
Can somebody help me here? I've spent so much in both time and money on this, its killing me to have her sitting there not running yet. Thanks in advance
