braeden
- Snowmass, CO
The rear upper shackle bolt on my 96 is seized to the sleeve of the shackle bushing.I can unscrew it untill it is no longer threaded into the welded nut, but then it starts pulling hte sleeve out with it, mushrooming the moutning area. I can't really get my angle grinder into it and if I grind the outside off, I will be left with a bolt that has about a 1/4 inch on each side and no way to unscrew it. Any ideas? and yes it has been soaking in penetrant.
