2001XJ
- Canton, MI
Anyone have an issue with rear pinion angle being just high enough to not allow high enough level of diff. fluid to lubricate pinion bearing properly? If so, how did you fix it?
I simply drilled and tapped a fill plug in the top of the diff cover and over filled the diff with extra fluid but eventually it will most likely work its way out the axle tube ends since the ends have dust shields, not proper seals.
