5-90
- Hammerspace
tow2topgun said:Ok I know what a drift is. Just never heard it called that...
I am about to have to change my RMS too. I however have a V6 2.8 motor in my 1985 XJ. Is this one as simple as you just described? I would put stop leak in it before I pulled the 160,000+ mile motor out of it. It needs changing but I have limited time, tools, and knowledge. I have pulled a motor and replaced bearings and a RMS in a 2.0 4 banger before so I have "some" working knowledge of a wrench.
Ugh. The 2.8L had two styles of seal - a two-piece "rope" seal (like SBChevvy) and a one-piece "ring" seal (like on an axle or the front main.) The "ring" seal requires that you are able to remove the transmission to remove the seal (it's held in with a metal retainer and four to six screws as well.) I haven't worked on a 60-degree V6 in a while, so memory is faulty. However, you can check out www.60degreev6.com for more information - that seems to be the central clearinghouse.
I do suggest you start looking for a RWD 3.1 or 3.4 donor (S-10/S-15 or F-body) to replace that aenemic little V6. Best upgrade I've found for them was about 400 pounds of ready-mix and two hundred feet of chain - then you can give it to your buddy with a boat. The 3.1 and 3.4L engines are vastly superior.
Don't neglect the FWD vehicles when looking for donors, tho. Find a FWD with a starter motor mounting pad on the backside of the engine (as mounted,) and you've got a Goodwrench Service Replacement engine - which is cast rather better, and compatible with both FWD and RWD/AWD/4WD as well. You may also find some RWD V6-60 in Astro/Safari vans, I think...
