Real cure to MPG in the Cherokee
Actually while the block is a joke the use of a couple of those sponge sanding blocks will do two things, keep you from mashing the pedal to the floor and force you apply more pedal pressure to keep it at higher speeds. If you force it to keep higher speeds two things will happen, you mileage will go back down and you will end up with an awsome set of muscles in your right foot and calf.... :laugh3: Think of it as an egg that won't break :laugh3:
