- Brighton, CO
I have a pair of Rubicon Express coils I'm not using anymore. I cut off a coil or 2 to lower my height and increase the spring rate. They're 21 5/8" long. I think they should give around 4.5-5.5" of lift. I had around 5.5" but I don't know if my mounts were higher than stock.
$40
2 Bilstein 5100 12' travel shocks.
M/N F4-BE5-6249-H5
29.70" extended, 17.91" collapsed 255/70 valving
Each has a dent on the lower lip of the shock, but it's not into the shock body and will not effect performance. They have JKS upper conversion mounts and Daystar EVS foam bumps on the shafts.
$100 for everything
-Jon
$40
M/N F4-BE5-6249-H5
$100 for everything
-Jon
