Take your axle to the absolute highest level of torque capacity with RCV. The same technology employed in our Dana 60 ’s high strength competition series joints goes into every set. Billet chromoly CV joints replace the old school u-joints combined with chromoly inner axles deliver more power to he ground. No more busted joints, egged yoke ears, or knuckle binding with this set-up. U.S. PATENTED High durometer spherical seals keep all the nasty stuff out and can take more abuse than any traditional CV boot. Set includes 27 inner axles for stock Jeep YJ width housings. Custom widths available. Comes with our “You break it and we’ll replace it” warranty. *This set requires the $44.95 Dana 30 27 spline disconnect block-off kit.*
Only 985.00/set! (Lifetime warranty against breakage)
https://rcvperformance.com/store/catalog/product_info.php?cPath=24&products_id=61
I Asked a Few Questions and here's their Answer.
They Look Awesome, however, Just a Few Questions.
Are these Produced Out of 4340 Forged CrMo Alloy Material that is Heat Treated?
Are the Splines Cold Rolled?
Are the Outer Shafts made of the Same Materials?
What would the Discount Code be?
Thanks.
All of our products are made from aircraft quality steel. We use a proprietary heat treat method that gives us the optimal strength that we have proven time and time again in our state of the art test lab. We can say without a doubt that we have the strongest axles on the planet. All of our products come with a "You break it, we replace it!" warranty. This will be the last set of axles you will have to buy for your Jeep!
15% Coupon code is: XJYJ
(only one coupon maybe used per set. no stacking.)
