8Mud
- Central Germany
had similar issue on my dads 96, its turned out to be the o2 sensors, changes it and fine
That's my next step, I have two new Bosch O2 sensors (Rockauto). I tested the O2 heater fuses and my grounds yesterday. I'm going to test the O2 heater circuit when I replace the O2 sensors.
I did find a significant battery drain yesterday. Something splashed on the side of my battery. I was getting 12.8 volts all the way down the side of my battery into the battery tray. Best guess is, it was either coolant or maybe a little battery acid had vented or a mixture of both. Which might explain my sluggish IAC issues. The IAC seems to be very voltage/amperage sensitive for some reason. I've seen voltage/amperage problems affect the IAC on both Renix and OBD XJ's, numerous times.
