joe_peters
- Grants Pass, OryGun
No problema.
All you really want/need to backflush is the heater core. That said, if you install the "T" in the heater hose that runs from the core/firewall to the water pump, then clamp the heater hose between the "T" and the water pump, turn on the hose, then you will be forcing a backflush through the heater core. Then you can use the "T" to finish the flush on the system in its normal flow--Ok?
