CaliXJ
- Oceanside, CA
91 sport, AW4, 231 combo.
So i'm in the process of doing a raidiator flush and figured i get a new cap while i'm at it. I've read to use a 16lb cap but the STANT book clearly says to use a 13lb cap for the 6 cylinder and a 16lb for the 4 cylinder. Is the book wrong? Ir is there a reason you guys are using a 16lb instead?
I'm guessing the book and the knuckle heads behind the counter are wrong... Just thought i'd check.
:cheers:
:cheers:
