I've found that by running my BFGs at pressures lower than most people would even consider, I get traction where others with larger and more aggressive tires do not. But, running very low pressures in radials without beadlocks over soft ground means you'll end up stuffing dirt and debris (weeds, twigs, sand, etc.) between the wheel and bead, eventually leading to slow leaks. These are easily fixed by breaking the bead and wire-brushing out the crud. Instead of simply snapping the bead back in place, however, I've found that laying a thin bead of silicone adhesive (I'm partial to Permatex brand, but honestly can't say there's any real difference) between the wheel and tire where the bead seats not only holds the tire to the wheel preventing burps or popped beads even at really low pressures, it keeps the crud from working its way in and creating leaks. The idea is to lay this thin bead of silicone along the surface where the tire actually seats against the wheel. This is not out at the lip of the wheel where most people assume. The tire actually seats on the flat surface of the wheel (parallel with the ground) just inside of the outer lip.
I've been getting about 6 runs prepped this way before I again have to break down a tire to clean out the crud. Running at low pressures like this, the adhesive really helps but crud eventually works its way in there as the silicone's bond wears out due to the movement between the tire and wheel.
It takes about 2.5 or 3 tubes of silicone adhesive to do all four tires - a thin bead is all that's needed as more just ends up oozing out on either side of the bead. When it's time to break the tire down again, the silicone just rolls out under finger pressure or if you hit a tough spot, the wire brush takes it right out.
It works quite well.
