hpi_jeep
- Mid-Missouri
i thought i had read that someone had ground down something and replaced an oil seal, and the 300 mated up to the aw4 without the 7/8" spacer.
also can i just redrill the rear housing on the tranny to "clock" the d300? it seems like if i were to clock it flat the top hole would be at the gusset on the top, could i cut the gusset off, or would it be better to run with one less bolt?
tia
i just cant justify spending ~$250 on a peice of metal.
tia
