TRAILREADYXJ
- Raleigh NC
wilcharl said:Its going to take a bit but the next step is to go from the sensor to the ECM with every wire to check for grounding out and for continuity... i would start with your CPS wiring.. If you have a C-101 bulkhead connector thats probley a good start
This is pretty much what I've done, I am going to double check myself though.
I don't have the C-101, but my friends XJ does.
Also my cps wiring is the newer type that goes straight to the ECU (seperate of main harness). I guess that's a good thing about having one of the last year renix models.
Everything I've tested has led to the ECU, but I know it is probably the least likely thing to go bad. I am worried I may have fried my extra ECU too, since I still had a bad ICM when I tried it. I'd hate to buy another one since it can't be returned.
I am going to recheck all the wiring and sensors (3rd time). I may just have to bite the bullet and get another ECU. This is also the only thing that would kinda make sense of why both Jeeps won't start now.
BTW, the fuel pump runs fine and I get plenty of pressure. The problem is definitly in the pulse signal from the ECU to the ICM.
Now where's my meter....
