Menzenski
Formerly Mambeu
I have a 1990 Cherokee (base trim level) with 4x4, 4.0 and a five-speed (which should be the ax-15, if I'm not mistaken). The transmission's been doing some funny things, and I'm hoping that it can be fixed without replacing it.
- When I start the engine and shift into reverse, there's a grinding sound like the clutch isn't disengaging, but the pedal is all the way to the floor. I've only noticed this right after a cold start; when the engine's warm, it doesn't seem to be a problem.
- 90 per cent of the time, the shifter won't go into any forward gear when the Jeep is at rest, which sucks because that means I can't put it in neutral at a red light. Usually I can get it to go into a forward gear by backing up, and shifting into first while still rolling backwards. This might just be co-incidence, but there was one day when I could consistently put it into a forward gear while stopped, and that day was noticably colder than most others.
- Shifting generally requires lots of force (both up- and down-, although up- is worse). Shifting into second and fourth especially, I really need to yank on the lever to get it into gear. I can usually get a smoother shift by staying lightly on the accelerator during the shift.
Any idea what these problems might be caused by? In the searching I did before starting this topic, I saw "synchromesh" and "slave cylinder" a lot, but I know next to nothing about transmissions. Thanks in advance for any responses.
