rkates
- indianapolis in
You'll still need to replace the carrier as the opening for the axle shaft is bigger on the 29 spline. The 29 spline shafts won't through the hole in the 27 spline carrier. At least that's what I've read.
This is true. I tried changing the side gears and axle shafts from a 29sp and found out the carrier had to be replaced too, so I just swapped axles.
As far as strength goes the 8.25 is very stout, even ericsxj is still running an 8.25 in his. Even on the d-35 I've seen more spiders blow before the c-clip gives.
The d-44 is a nice axle,If you can find one. But for the money the 8.8 cant be beat. Unless you find a small one it has 1 more spline on the shaft than the 44 and the ring gear is bigger. Aftermarket is crazy with parts for it too. And if the c-clip still scares you, the 8.8 has one of the cheapest c-clip eliminator kits I've found.
All of this being said, I am still running an 8.25 in my jeep and just got done regearing it. You just have to look at how you want to drive it. Than decide what you can afford.
just my $.02
