i have amanual but im not quite sure i understand the powertrax no slip, if its no slip then its a regular lunchbox locker right just like the aussie? if i have it in 2wd will the front one engage at all? or would it be completely disconnected from use untill 4x4 is engaged?
Also, for the rear obviously the powertrax no slip will be being used but will it engage if i drive it normally as a daily driver? will it cause any adversse suspension wear or should i just get an LSD?
As for the rear, obviously it will be
