- MilkyWay Galaxy
jeephick85 said:OK just changed the TPS its not zero in yet, now what exactly am I looking for number wise when I adjust it. Right now its on seems to be shifting better but it still has a choppy idle.
Use the square connector, A is the ECU 5 volt input, B is the TPS return output to the TCU. D is the ground wire. With all power off, D should read less than 1 ohm to the negative battery post, ground. If greater than 1 ohm fix thwe bad ground wire conection, or clean the ground contact areas and run new ground wires. Then the B return wire when the TPS is connected to the wiring harness and with the power, ignition switch on, engine off, do not start it, test the return voltage (B to D) on the TPS, it should read 83% of the TCU input voltage (A to D), if not loosen the TPS mounting screws and rotate it until you get 83%.
