rstarch345
- Where ever I can wheel
So far over 90,000 miles on origional set of Bosch Platinum +4.
As i stated use the ones it was engineered for and yes espesially in a turbo ford running 18lb boost he he ........60thAnivrsryXJ said:The only way to go with any vehicle is dealer plugs. Champion for Chrysler, AC Delco for GM, Motorcraft for Ford, etc... This has to do with the heat range of the plug, aftermarket plugs like autolite are made so that a certain part number will fit many engines, it could be too cold a plug on one and too hot a plug for another application, or you could get lucky and it be perfect. The dealer plugs are more specific and it will be exactly the right plug instead of taking a gamble with aftermarket. By the way I have heard that Fords are the most picky about this and you should expect trouble if you use anything besides motorcraft with them.
As far as Im concerned anyone who would run 90k on any plug is smoking way too much breakfast...........rstarch345 said:So far over 90,000 miles on origional set of Bosch Platinum +4.
majic_tech said:As far as Im concerned anyone who would run 90k on any plug is smoking way too much breakfast...........
majic_tech said:Anti seize is advised for aluminum heads but not a necessity on cast iron
majic_tech said:I think someone was pulling your leg there
casm said:2000 Limited, 4.0, NP242, needs to see more dirt, ran over a squirrel on the way home from work today.
I've been running the Champion truck plugs for about the last nine months or so and can't say that I notice a damn bit of difference between them and the Autolites they replaced apart from that my wallet's now marginally lighter. This has been over about 18000 miles or so; when I change them out in another couple of thousand miles I'm going back to the Bosch Platinum +2s. Ran great in my '01 Sport, noticeably better than the stock NGKs. YMMV.
Avanteone said:I'm sure I mentioned it above, but I own a repair shop, have for 10 years. We install lots of spark plugs. Anti-seize goes on EVERY spark plug. Zero problems. And I still stand by my original opinion, in these engines, the stock Champions work best. hasta
John
IH8RDS said:99 4.0 90,000 miles still running stock factory installed plugs that came with it new
