Looking for: a full set of spindles, bearings, hubs, rotors, calipers, caliper brackets, lockouts, etc (no knuckles or shafts needed) off an 8 lug dana 44. Parts don't need to be new, but do need to be in usable condition, especially the hubs, spindles, and caliper brackets.
i have all the dumb shit i have posted already that nobody wants.
and EVERYTHING you need to convert a smallblock chevy to tbi fuel injection with some new and used parts.
I did (thanks a ton btw), but I'm hoping I can find someone to trade stuff with who is looking for the same things I have and will be at chickenfest. Figured it was worth a try.Did you see this link I posted before?
http://www.pirate4x4.com/forum/axles-tires-wheels-sale/1109427-dana-44-8-lug-outers.html
Ken any idea if that trans spline count will fit behind a 24 valve cummins?
Duh you said output shaft! Sorry.
hmmmmmm.
Got anything interesting? You know me, if it's reason to consider some other ill planned mod to my jeep, I'll let it sit in the yard for a while.
edit: Stefan, as far as I know it won't bolt up to a cummins without changing the bellhousing and input shaft, and it won't bolt to a diesel transfer case (29 spline input shaft on those) without significant mods either. It's basically not worth it unless you don't mind having a glass NV4500 instead of a glass chryco auto. It's fine behind a gasser or in a jeep, though.
Maybe, I gotta figure stuff out. Any idea what gears are in it btw? I think I asked you this before.
