A pipe bender is NOT a tube bender..... Dont waste your money on it, it will not work...
If you cannot afford a good tube bender but still wish to do it yourself, there is another option.....
DO NOT use black iron pipe it will split.....
That said......
Get your tubing and weld a freeze plug or some other suitable plug on one end. Get a bag or two of play sand, the kind they put in kids sandboxes (it should be as fine as you can get). Make sure it is COMPLETELY dry before you start. If you have to, spread it out on a tarp on a sunny day. It must be totally dry or you will have a pipe bomb on your hands!!
Fill the tube about 1-2 feet up then find a way to compact the sand. We used to use a wooden dowel that fit closely inside the tube and a pnuematic chisel gun with a planishing head. Add another 1-2 feet and repeat until tube is full and all the sand is compacted TIGHTLY!
Weld a freeze plug on the other end without disturbing the sand if possible.
Put the tube in a vise and heat with a torch until it is almost red hot in the area you wish to bend. Give it a push and VIOLA!!
If it is a steep bend like 90* you may have to heat it up more than once...
Grind off the plugs and remove the sand and you are done!
Disclaimer as follows... If you or anyone else follows my advice you could get hurt or worse..... I am not responsible for your actions......
