- sacramento
Sorry brother i had some craigslist flakes today suppose to buy my dune buggy but flake (jeep fund)
its all good man. just keep me posted.
UPDATES ON PRICING AND FREE STUFF
I don't want to ship anything
a door I started to cut into a half door
Free front trim around the grill with headlights (IPF?)
Free renix airbox, kinda chopped up, I think it has a tube going to the cowl out the back
free stock fan clutch
free steering column
misc bolts for an XJ
I have a big pile of free stuff on the side of the yard
if you take a car load of free parts bring a 6 pack of coors light if you can...
NEW PARTS ADDED HERE:
77 mercury grand marquis master cylinder, napa brand, rear disc master, not drums, bolted to a 1996 booster with lines to adapt to an XJ
the booster pushrod has been modified to work on a renix XJ
this is what I just installed recently, worked great, I recently replaced the entire braking system, it stopped on a dime...
50$ for the booster and master
wilwood proportioning valve and a electric line lock from summit racing, never even wired up the line lock
70$ for the prop valve, line lock, and hoses
steering box brace, the one that bolts from frame rail to frame rail
20$
spare 15" rim, black steely, 5 on 5.5 lug pattern, I think it was 4.25" BS but not 100%, could be 3.75" too.
20$ obo
JKS front upper stud eliminators
brand new
put about 5 miles on them
30$
Winch bumper with tube and some dents
needs the driver side mounting straightened out, I got lazy cutting off some welds and took out a 12lb sledge
220$
Smittybuilt 10K winch(not the cheaper 8K ones)
I've used it 2X, worked great each time
220$ obo
(5)
37/12.5/15
old style wrangler MTRs
a ton of tread maybe 80-90%???
throwing in mismatched rims for free as of now
mounted and balanced on 3 5 5on5.5 rims and 2 8 lug rims
1160$
2x4 .120 cross member,utilizes 3 factory cross member bolts, not just 2 .
clearance for exhaust
has studs welded to it for bolt on skids . skids not included.
70$
alternator relocation, alternator drilled out for bigger bolt, and brackets and extra belts for the shorter setup,
with a spare alternator already drilled out,
includes 2 alternators in working shape, one is very new that was on my rig,
one was known to be working spare
3 or 4 of the 77" belts so you are set forever. o
renix era
80$
stacked plate heavy duty tranny cooler
30$
derale 2 pass round style power steering cooler
30$
91+ exhaust manifold
30$
91+ intake manifold with injectors and throttle body
30$
bilstein 5100s
27" long extended 12 " travel
60$
pro comp ES9000s
33" extended 14" travel
50$
pacesetter long tube header for renix era XJ
added a flex fitting into one of the pipes. that alone was 35$
this will need some welding . I had to cut it up.
75$
gas skid factory.
20$
Cab I come pick up the line lock and wilwood propvalve?
Do you still have that motor??
