Parting 96 XJ on Tons
WAD357
Eastern LI, NY
Well after alot of thinking Im goin to part out my XJ..
96XJ Shell full stiffiners little bit of rot on the trunk floor Harness for a renix in it LCA mounts cut off some Dings and Dents nothing major no motor no trans $ Best Offer
79 Ford Dana 60 High Pinion King Pin 35 spline inners 30 spline outers 5:38 gears new bearings Ford LSD that works MINT locks up nicely. King pins were rebuilt with new bearings. Comes with heim Joint steering all 7/8" Ruff Stuff heims. Setup for a custom 3 link. All new brakes Calipers rotors pads and wheel studs hubs drilled to take a 9/16th stud. Looking to get $2000 with steering steering is 1.75x.250 DOM
01 Ford Dana 60 Semifloat rear 35 spline shafts 5:38 gears new bearings BOLT IN to an XJ comes with ruff stuff spring plates and u bolts. New pads rotors and calipers in good shape $1000
H2 Wheels with 36x13.50x17 IROKS Tires are hurtin wheels have some rock rash $300 obo
21 spline NP231 works mint $75
KING Resi Shocks 10" travel 18" collapes 28" EXT $400 for the pair
Anything else you see make an offer
You gotta fancy pants aluminum rad in it?
Nope....
Axles Wheels and tires sold...
Someones gotta want some shinny shocks!
