xj_mike
- San Diego, CA
Hey Sean, just an FYI, my wife GOT the day off so we are planning on going.
If you hop on to PanamintValley.com or YouTube.com, you'll see plenty of people doing Pleasant Canyon in 100% stock Blazers, Jeeps, Monteros, FJ's, etc etc etc. I've also seen camper vans going thru there. There might be 1 or 2 sections that might require 4WD. The vast majority is moderate clearance 2WD.
There's also no tight switchbacks at all. It's all wide open enough for an H1 to navigate easily (except for chicken rock and the log bridge).
I'm open/open on a D35, been thru there a few times with even less! I don't know how they would call that a 7 out of 10. It's closer to a 5.
Anyhow...the Pleasant/Surprise Loop is the most common/popular loop out there. It's also more entertaining, and much shorter, than Mengel Pass on through Warm Springs and Shoshone (this route would total almost 600 miles from OC and back).
Getting to the cabins at night, you don't go thru Pleasant at all. You go down Wingate Rd and up the first couple miles of Surprise Canyon. Again, any stock 4x4 is more than enough. Using the cabins as base camp, we can head toward Pleasant (either up or down), and if it gets hairy, we can always just turn around and go the other way!
Mengel is just like driving down a dirt road. I doubt we'll use 4WD at all there.
That said...do you need the trailer for just a Sat/Sun trip? Maybe you could leave it at home? I'm sure you'd be fine either way though.
But trust me when I say your setup is well above and beyond Pleasant Canyon material. A bone-stock XJ would do fine there. I took my mom's stock 1993 Grand Wagoneer through that loop back in high school. Don't tell her. lol. Cooper street tires and all.
