skipc
- Georgia & points west and south
What little info I have says they are analog outputs. Has a single line in for the ECU, and one out for the ECU and another for TCU. First thought would be how to get it to 'talk'. It probably doesn't sit and babble on the output just running, it'll need a command to dump its values.
Everything just says to use the DRB II to get there....
Maybe it's just a case of grounding the 'input' and the output pulses the codes like the older Ford systems and everyone has been fooled into buying extra boxes. ;-)
5-90 and satan seem to have been into this, are they still around?
BTW, I used like to hook the OBDII scanner up my 96 Explorer and monitor everything real-time. It wouldn't be too costly, or difficult, to add a monitor in the design. Most people I know would buy it as a factory option if it was available - just to keep tabs on things at least. It would be one cool option, but those same folks that invented idiot lights probably wouldn't understand :-(
