Skreed
- Phillipsburg, NJ
I don't agree with that a good o2s will fluctuate voltage between about .3 and .7v reguardless of rpm.
I didn't mention this earlier but I also replaced the fuel pump and filter but I doubt it has anything to do with fuel pressure or fuel delivery because as I said before it happens on LPG too.
casm said:One other possibility is that something in the LPG conversion has an air leak that's showing up under normal running. I'm no expert with LPG by any means, but from what little I remember of how it plumbs in there are a couple of potential points of failure.
Have you actually tested one? Hmm, I have!
Sure all the time! I am not just pulling this stuff outta my ass.
I was just looking at one today, thats why I posted up.
The information in the in the link you posted I already know, not to mention it doesn;t back up any of the facts you stated.
The O2s voltage peaks will come closer together when RPM increases, meaning the voltage is flip flopping more.
That being said I am just trying to help someone out, thats all.
OTC oscilloscope.
So you are saying my 02 sensor appears to be working fine at 2000 rpm but what about my 'bad reading' at idle (i.e. - the high voltage of .940v steady)?That is good...O2 sensors have a voltage of 1 volt. .5v is "perfect" mix so to say, but thats not how the computer works. It will fluctuate between about .2v and .8v to "keep" the mix at or near the target of .5v
A bad reading would be constantly high or low. Lean=low voltage Rich=high voltage
Hi casm,It's been a very long time since I've dealt with anything LPG-related (and even then not extensively, nor on an XJ), but from what I recall of the conversions there's typically a valve that controls LPG feed into the fuel system. If there is a leak at whatever seal exists between that valve and the stock fuel system, air could be being sucked in which would explain why this happens under both fuels. However, that's not to discount any of the earlier suggestions as it really is a shot in the dark on my behalf.
Also, I can't find any mention of fuel pressure numbers in this - I may have missed the answer in reading back, but has it been tested at the fuel rail under gasoline-only operation?
XJSteven, do you have any photos of the LPG conversion? It may be worthwhile to see how it plumbs in to the fuel system - not to place blame on it immediately, but rather so that we better understand how it all ties together.
There are no damaged or shorted wires. It might be too soon to speak but 3 days ago I cleared the error code twice and at this point it hasn't come back on (fingers crossed!). All I've done in that time is disconnected the oxygen sensor a couple of times during testing so if I'm lucky I might be able to put it down to a loose connection at the plug, even though I've had it disconnected before. I will continue checking for the error code over the next week or so and whether there is an improvement to my fuel economy!Check the wires to see if they touched the exhaust manifold and got shorted or damaged.
This one is puzzling. I am going to say the computer thinks the engine is running lean, and is adding fuel to compensate, but that the computer is not seeing the rich fuel mix data from the O2 sensor. Sounds like a signal voltage drop between the sensor and the PCM to me, bad wiring or connections between O2 sensor and PCM.
As a 96 you have an OBDII system that doesn't have a 60 way connector at the PCM, you will have 3 connectors at the PCM.
Was this reading when fully warmed up?
Here is a photo of the LPG conversion. Looks like the LPG feeds into the system in the same place as the air does:
No, I haven't yet tested the fuel pressure under gasoline-only operation.
OK stupid question but if I were to check the wiring at the PCM how would I locate and unplug the 3 connectors? Here's a few photos of the PCM...I can't see any connectors and I can't feel any underneath the PCM either.
I might not have posted this but I tested the 2 ground wires and they were good so I cleaned the G101 bolt up anyway. There was 13.8V power going to the heater and I got a reading of 5-6 on the ohmmeter when I checked resistance across the two white wires to the sensor.Good question. Did we check the heater resistance and voltage on the O2 already? I forget.
I'll give this a try and see how I go.Remove the airbox and it'll all become much clearer. My memory is that there's basically one wiring trunk (the one you're probably feeling) that comes into the PCM where it subsequently splits out to three separate connectors. Can't recall if you have to remove the black cover over the PCM to see them or if they're visible once the airbox is removed (it's been years since I've been in there), but it should be apparent once you've made some room in there.
Thanks for the offer 90xj06 but I'm a bit too far (other side of the planet ).if you where close to me i could plug my reader in and go through the tests
