Blaine B.
- Northwest Indiana
Now that I think of it, I did try a pipe wrench at first, and found a crescent to be much easier to use.....just from my own experience.
Blaine B. said:Now that I think of it, I did try a pipe wrench at first, and found a crescent to be much easier to use.....just from my own experience.
Blaine B. said:I'm cheap and young
beauwoods said:Ok when you have tried all the above and the damn thing still wont budge then what? I have a 92 xj and the damn thing is on there tighter than a 12 year olds vagina (sorry borat quote). I have used PB spray, ran the engine till hot, tried crescent, pipe wrench, robogrip , open ended wrenches, and even that damn tool they make just to remove them (snaped that thing in half) and the thing still wont budge. I have allready bought the new sensor so I dont want to take it to anyone. Should I heat it with a torch? or maybe some damn C4 that will get it loose.
beauwoods said:So I know its off topic to this thread but anyone have any suggestions as to what I should replace aftersix years of lets say almost no maintenence?
beauwoods said:Thanks for the suggestions, that wax one is a hell of a trick. I am pulling the heads off, so now I will be able to get a better angle at that damn thing. This Jeep is a mess but its all my fault, I neglected her for about 6 years with very minimal anything done to her, only if she needed it but I went wayyyyy over oil changes a couple times. Ahhh my younger more I dont give a damn years. Now I have decided to go through her almost completly after deciding to peer into the oil fill cap with a flashlight:doh: . Man I have never seen lifters that gummed up. So I know its off topic to this thread but anyone have any suggestions as to what I should replace aftersix years of lets say almost no maintenence?
My list so far includes:
Fuel filter
oil change ( I think now after peering inside her I should pull the pan)
Cap & Rotor
Plugs and Wires
Radiator W/ new thermostat
Tranny filter
Engine Mounts (one was half missing )
Air filter
Carb has been cleaned
(oh and inside I am redoing the interior and have put in a little 12" to make her boom :spin1
Fuel filter
Cap & Rotor
Plugs and Wires
Tranny filter
Air filter
